Go Back   Toyota Supra Forums! Join the Supra forum! > Performance, Modification, and Maintenance Forums - for generation specific discussions > MKIII Supra > MKIII FAQ
Old 03-06-2007, 04:49 AM   #101
dcrusupra
dcrusupra's Avatar
Is it the 2 white connectors (they were connected) or is it the one hanging down in middle?
New Rebuild
My CarDomain
Old 03-06-2007, 06:16 AM   #102
88Tsupra
88Tsupra is on a distinguished road
QUICK question i have oil near the fan belt i dont know whas its called buh its the metal shit that connects the motor fan to the motor..is that a BHG or just some really F'en bad oil leak and how can it be fix
88turbo targa-white
original Pin Stripe
custom intake-Tenzo filter.....Momo racing seats and steering wheel...
apexi exhaust tip-custom 3" piping. Replaced with RSR GT II
NGK plug and wires
HID conversion head lights
HKS Turbo Timer Type-1 (in black)
Tial BOV
BIC DDP
88Tsupra is offline   Reply With Quote
Old 03-06-2007, 06:33 AM   #103
dcrusupra
dcrusupra's Avatar
Any pictures? Is it coming from around or under the crank pulley? (The lowest pulley in the middle)
New Rebuild
My CarDomain
Old 03-06-2007, 03:37 PM   #104
JMoses
JMoses is on a distinguished road
Originally Posted by JMoses
Do you have any more pics of your engine around the starter area. I have a couple of plugs on my wiring harness and I cant find out where they go.
??? If you have any of those pics I really need to see them. Those two wires and one plug are the only thing stopping me from having the beast running again.
JMoses is offline   Reply With Quote
Old 03-06-2007, 03:42 PM   #105
IHateHacks
IHateHacks's Avatar
"I just put a new head gasket on my supra and that wiring runs over the top and then down the drivers side of your tranny. If I remember correctly there are bolts that hold it onto the tranny."
Yes, I know it bolts to the tranny, I was asking how to DISCONNECT the connectors as they are above the transmission. And the wiring goes through the lower intake manifold, therefore preventing the head to come off the block WITH the lower intake manifold still bolted on. Or it prevents the lower intake manifold to come out of the engine bay for cleaning. Problem was solved about 2 months ago, by doing what jfunez said.
"Do you have any more pics of your engine around the starter area. I have a couple of plugs on my wiring harness and I cant find out where they go."
Yes, I have plenty of more pictures. Why don't you post pictures of the connectors that you do not know where they go and Ill tell you where they go.
"QUICK question i have oil near the fan belt i dont know whas its called buh its the metal shit that connects the motor fan to the motor..is that a BHG or just some really F'en bad oil leak and how can it be fix"
Sounds like your fan clutch fluid coupling is leaking. What ever happened to starting your own thread instead of hijacking a thread that has nothing to do with your problem? Take a picture and post it. Pictures speak louder than words. If you don't have a camera, get a job.
Old 03-06-2007, 03:45 PM   #106
IHateHacks
IHateHacks's Avatar
The one with the clear connector is for the speed sensor.
The one with the white connector is for the reverse lights.
Old 03-06-2007, 07:41 PM   #107
88Tsupra
is a 1.5mm MHG stock size HG or do i have to get it machine shaved n e ways
88turbo targa-white
original Pin Stripe
NGK plug and wires
Tial BOV
BIC DDP
Old 03-06-2007, 08:08 PM   #108
88Tsupra
hey im confuse i went on hksusa website and they had MHG bead and stopper do you need to buy both or just one and which one is better
88turbo targa-white
original Pin Stripe
NGK plug and wires
Tial BOV
BIC DDP
Old 03-06-2007, 08:49 PM   #109
IHateHacks
IHateHacks's Avatar
1mm is the stock head gasket thickness.
Bead and Stopper gaskets are 2 different kind of HKS head gaskets. Stopper is much better than the bead, cheapest HKS stopper head gasket I've seen is $355 and its 2mm's in thickness.
Don't even bother buying a head gasket until you have the cylinder head off of the block. Because that will be the only time you will be able to determine IF your cylinder head and block are in proper condition to be able to use a Metal head gasket. I wasn't able to use a metal head gasket because of the pitting around the exhaust side's coolant passages at the #6 cylinder, which is, by the way, the most common area for the supra to blow the head gasket.
Old 03-06-2007, 09:34 PM   #110
88Tsupra
was it the pix were ur head gasket lookd like oil was sitting there for along time...cuz when i changed my plug i notice i had oil in 5 and 6 buh the rest was ok buh then plug 5 and 6 lookd a lil burned..is that a sign..and if i just get a stock size HG will it still blow on me if its not a MHG..also i plan on building the motor up to plus around 400hp...its going to take me about A year or 2 to get it to 400hp because im just going to take it slow..so if i attempt to get 400hp the MHG is best right?
88turbo targa-white
original Pin Stripe
NGK plug and wires
Tial BOV
BIC DDP
HTML code is On
Blown Head Gasket Symptoms! Dejvid1785 MKIII FAQ 76 04-24-2011 07:59 PM
Blown Head Gasket Snake Oil unkymurch Non-Generation Specific Questions 21 08-06-2010 02:11 AM
Update: Blown Head Gasket Snake Oil - 8 months later unkymurch Non-Generation Specific Questions 3 12-17-2008 09:35 PM
Head gasket repair Kuban MKIII Supra 9 07-20-2007 09:01 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86
