Old 05-11-2007, 12:05 PM   #1
ebang
Default Clutch Master Cylinder Help please!!
I was trying to replace this and could not get to the one nut on the left...i tried for quite a while and finally got fed up...how the hell do I get to and remove that nut?....help!!
1987 N/A Targa 5 speed
no mods as yet
Old 05-13-2007, 09:10 AM   #2
shortman
shortman is on a distinguished road
Smile Clutch Master Cylinder
I don't have any tips as of yet - but I'm going to do this same thing within the next week. After looking again - it looks like an extension and the feel of the fingers might be the answer here. I think the real tough part might just be a fat man laying on his back on the floor board trying to play under this dash. Might be a week but will keep you posted.
shortman is offline   Reply With Quote
Old 05-13-2007, 02:19 PM   #3
ebang
I will be trying again today I think my best bet will be a 12mm stubby
no mods as yet
Old 05-13-2007, 04:31 PM   #4
supradaddy0803
supradaddy0803's Avatar
I used a gearwrench worked great I did mine because it was leaking on my 86.5. Did you think about rebuilding it instead of replacing you just need a small cylinder hone and the kit. The rebuild kit is like 12 dollars thats what I did worked out just fine. But if anything I think the one on my JDM clip might work on a US version car so I got a practically new one.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Old 05-13-2007, 04:56 PM   #5
ebang
well finally got it...the 12mm stubby did the trick..
no mods as yet
Old 05-13-2007, 05:36 PM   #6
j3pz
omg those lil nuts are pia. when i did mine, one fell behind the kickboard with the fuses... what a bitch... finally found it with cut up wrists and a magnet... but now i know how to do it and will make the next time easier
How hard is the clutch master cylinder to replace? the#1 MKII Supra 2 05-27-2016 04:32 AM
Clutch Master Cylinder question. 1989 Supra. PFlanagan MKIII Supra 4 08-07-2008 08:20 PM
