Old 03-28-2010, 10:11 PM   #1
tak2099
tak2099's Avatar
tak2099 is on a distinguished road
Default vsv question
What are the two vsv's located under the intake manifold for? I broke one (the one towards the front of the motor) and it costs 75 from Toyota, and i was trying to figure if I really need it.
1988 supra turbo. In process of modding:Roll cage, seats, dp, 3" intercooler, fuel upgrades, and turbo upgrades next.
tak2099 is offline   Reply With Quote
Old 03-28-2010, 10:21 PM   #2
Fuel pressure up and EGR vacuum control... and yes, you need them.
Old 03-28-2010, 10:25 PM   #3
tak2099
tak2099's Avatar
Well, I dont have egr any more, and why exactly does the fpr need a vsv? does it cut down fuel pressure at idle or something?
Old 03-28-2010, 10:44 PM   #4
tak2099
tak2099's Avatar
Never mind, read about it. Is it still needed with an adjustable fuel pressure regulator? And if it is, what would happen if you removed it?
Old 04-10-2010, 04:54 AM   #5
Bru
Bone Stock w Upgrades ;-)
Bru's Avatar
Default VSV (Vacuum Servo Valve)
Hello
The (energized) power up VSV allows atmospheric pressure to the fuel pressure regulator at start up and for one minute after to give a higher fuel pressure than the vacuum regulated pressure. Helps to start faster idle smoother. Removing it or having one that is defective means that fuel pressure will always be regulated by manifold vacuum or pressure. This can be a problem for a heat soaked starting engine. A rough idle at start up due to vapor lock can result.
The (energized) EGR VSV also blocks off the vacuum and allows atmospheric pressure to the vacuum modulator of the EGR keeping it closed until the engine reaches operating temperatrue. Removing it or having one that is defective means that manifold vacuum will be applied to the vacuum modulator when the engine is cold. It can result in rough cold acceleration / running. Note that vacuum is not applied to the vacuum modulator at idle. The throttle has to crack open for it to operate. Otherwise the engine would stall.
Here is a helpful link about Toyota's EFI system including the 7MGTE engine.
http://www.autoshop101.com/forms/h22.pdf
Old 04-10-2010, 09:08 PM   #6
Green7mgte
Supra Forum Moderator
Originally Posted by Bru View Post
nice link!
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 04-10-2010, 09:54 PM   #7
here's much more on that site too. Here's the link to the technical pages section: http://www.autoshop101.com/autoshop15.html
Old 04-11-2010, 02:24 AM   #8
Bru
Bru's Avatar
Default Supra VSV
Thanks for the homepage link.
After reading the article (and not being sleepy) The main purpose of the EGR VSV is to keep the EGR valve closed until the engine has warmed up by blocking the vacuum. Even a defective VSV has some functionality. The default (unenergized) state of a VSV is to allow vacuum to pass through. The result would be a little more nitrous oxide pollution until the engine has warmed up. JDM Supras don't have a EGR system at all. A defective Fuel pressure up VSV would allow vacuum to the regulator at start up and as usual.
Driveability would not be greatly impacted by a malfunction of either VSV provided the hoses are connected.
Old 04-11-2010, 07:24 AM   #9
JDM Supras also use different timing and fuel maps which take the higher combustion chamber temps into account.
Old 04-11-2010, 07:29 AM   #10
Green7mgte
ok im sorry to ask, but what is a JDM supra? something from japan? Im really in the dark about this. Ill research it tomorrow but if someone knows before then. Fill me in please.
Supra FAQ
Supra MKIII FAQ
Question about 7m-gte. AzNbOi2626 MKIII Supra 3 03-29-2011 06:55 PM
Starter Removal question OkieRA29 MKIII Supra 13 05-11-2010 12:08 AM
turbo or not ??? That's the question ... sausa MKIV Supra 7 03-30-2007 02:22 AM
Help! Question on front NOSE and bumper supports. lifesnotfair MKIII Supra 1 12-26-2005 03:54 PM
Quick question AutoXMan MKIII Supra 12 09-30-2005 06:40 AM
