Old 05-14-2012, 02:55 PM   #1
dardena
dardena is on a distinguished road
Default 82 EFI clogged fuel filter?
Hello, I have a 1982 supra LS with the fuel injection. It ran OK until sitting for several weeks, but now it will try to start... the engine "catches" and runs for about a second, then stalls, usually with a couple of backfires.
When I remove the air intake and spray starter fluid, I can keep the engine running, so it must be a problem in fuel delivery.
Anybody have any suggestions as to how to fix this problem... or even what to be looking at?
Thanks,
Terry
dardena is offline   Reply With Quote
Old 05-15-2012, 12:05 AM   #2
if you believe this to be a fuel problem your looking at a fuel filter clamped to the block under your intake manifold. and a screen/filter in the tank. i will put my money on the tank filter. there is also the chance of a third somewhere in the lines. you never know what some people have put in....
Old 05-15-2012, 02:05 PM   #3
http://www.cygnusx1.net/Supra/Librar...aspx?S=FI&P=45
this should help you. but remember things will be different as the manual is for an 86 and you have the 82.
Tags
cold start, fuel filter, pump
mk3 supra fuel filter 2fast4u MKIII Supra 7 04-18-2012 10:55 PM
changing fuel filter 3.0trd MKIII Supra 9 04-22-2008 10:47 PM
Fuel filter location? supraman121 MKIII Supra 1 05-26-2007 08:23 PM
where is the fuel filter located??? redmaro MKIII Supra 3 08-23-2006 04:31 PM
Fuel Filter 559turbo MKIII Supra 5 11-23-2005 12:22 PM
