Old 11-28-2004, 08:55 AM   #2
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
well... fuel cut isn't set on rpm or boost really... it's purely on flow of air... so on a cold night you will be more likely to hit it... are you running stock boost? no boost controller hiding in there anywhere?
then you can go 110 cruising (5th gear)
cruising h34r:
you should definitely not be hitting cut
explain more of your fco issues
Pics of my build.
Do a diagnostic first!
supra head gasket questions+ rebuild Andy C MKIII Supra 169 05-18-2010 01:59 AM
Fuel pump relay and pressure. carfanatic89 MKIII Supra 8 05-01-2008 06:39 PM
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
Fuel cutoff 1988gte MKIII Supra 4 11-04-2005 11:08 PM
Fuel injectors Biku Off Topic Forum 7 07-23-2005 04:36 AM
