Go Back   Toyota Supra Forums! Join the Supra forum! > Any questions about Toyota Supra > The General Questions
Register Blogs FAQ Members List Calendar Search Today's Posts Mark Forums Read
LinkBack Thread Tools Display Modes
Old 09-03-2008, 10:22 PM   #1 (permalink)
bowhunter951 is on a distinguished road
Default Vaccum tube ID help
I have a 1986.5 TOYOTA SUPRA . I'm having a problem with my heater it does not work. I noticed that it was broken the winter after the car got a new engine put in. The car went to 3 shops including the one that put the engine in and none of them could fix it. The heater control valve is working. I thought it may be the motor on a air door. but I was looking around and noticed that both connectors on a vaccum swich (located near the thermostat on the radiator) were broken off and there were no vaccum hoses going to it. I found a pic of the swich online. Could anyone tell me where the 2 vaccum hoses go to?
Its the one on the top left
bowhunter951 is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!
Old 09-04-2008, 02:45 AM   #2 (permalink)
Busted Knuckles's Avatar
My heater vacuum line connects to a tee coming off the Cruise Control vacuum motor. If the vacuum switch is broken, like mine, by-pass it, and hook the vacuum line directly to the vacuum motor on the heater valve. Works fine for me.
Busted Knuckles is offline
Old 09-05-2008, 02:19 PM   #3 (permalink)
Super Moderator
ddmcse's Avatar
Cool
toyota Supra pictures heater issue
300+ RW HP Dyno run,
Blown HeadGasket info
12 Years behind the wheel of a Supra
ddmcse is offline
Old 10-04-2008, 10:09 PM   #4 (permalink)
Default Update
So, I still have not quite figured out where the 2 vaccum hoses that come off the thermostat housing BVSV go. Mine are missing and I can't figure out where they are sposed go or if they control the heater. As seen in Picture. Any help would be appreciated.
Old 10-05-2008, 12:39 AM   #5 (permalink)
Bill UK's Avatar
Looks like they connect to the vac and charcoal canister. We don’t have charcoal canister in the UK, so ours are capped off.
Bill UK is offline
Old 10-05-2008, 12:51 AM   #6 (permalink)
Bill UK's Avatar
This is from the online EPC Link , will check mine out tomorrow morning.
Bill UK is offline
Old 10-05-2008, 01:55 PM   #7 (permalink)
Super Moderator
ddmcse's Avatar
Cool
your switch is busted,
take hose # 88690C pull it from the bottom of the switch , and plug it into the the top of the like you see in my picture from the post above. when you step on the gas the value will open and you'll get heat .
ddmcse is offline
vB code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
