10-03-2005, 09:56 PM
#24
Originally Posted by Poodles
ok, to drift, you don't want body roll, as that will plant a tire and stop the drift. Also, I wouldn't recomend using the E-brake on a supra, unless you want to replace the shoes, and they aren't cheap. Also, drifting is done with power, so you can smoke em.
What you need, is a stiff suspension, LSD, lots of power, and lot of experience to do it. Drifting is cool, but tires aren't cheap
i believe in you on that. i pretty its a good setup that you have. same on here. hardly use E-brake... i got a 85 mk2 supra turbo.... pretty much i do double clutch n double gas..... n i hardly use E-Brake... i believe for what you said. peace out.
