Old 04-06-2011, 04:04 PM   #1
bbullsj
bbullsj is on a distinguished road
so i took a closer look digging into it and found that when i took off black wraps that go around the wiring that i do have what looks like a red wire to going to one and a green going to another. i assume the green one would be blue. the problem is that i can't decipher either wire on g1, g2 has the green/blue wire and the NE has the red wire. that doesn't match up with what colors you said they should be :S from that diagrahm did you just figure out which pickup went to which location in the connector and crossed that with which color wire went where in the connector? i think i should probably rewire it with the colors that are on it but usually when people replay to posts they know what they are talking about. i just dont want to do it and it be wrong and have to redo it.
bbullsj is offline   Reply With Quote
