Old 07-28-2010, 02:00 AM   #1
You need to fix ALL external leaks before you can be sure how much you're loosing internally... BUT the amount which collects in the IC is a good indicator as to where things are.
I meant a rebuild when I said overhaul... shouldn't have used that term, it's vague.
