Originally Posted by mrnickleye
OK...after an hour of research, it appears you can unplug, or remove, the TDC. Then ground the #3 terminal of the starter relay in the Rt. kickpanel, which will allow starter operation.
Any input???
You can do this and it works. Unplug the harness from the security system. You can either ground pin 18 (I think) on the harness, or you can do what you described. I just made a little harness for the starter relay to plug into, and grounded terminal #3. This is MUCH easier than trying to find the correct pin to ground in the security system harness, as this is up inside the dash area.
