Thread: HP Upgrade time
Old 04-18-2007, 04:36 PM   #3
Supra_87_mk3
Supra_87_mk3's Avatar
Supra_87_mk3 is on a distinguished road
Lightbulb not to be mean
i dont think you realize that im not retarded i know that you need more than one gasket i have the gasket set i wanted an after market HG to lower the chance of it blowing. and yes i am taking it to be resurfaced.. also i have done this head jod on a N/A 2 times and i do realize they are stretch bolts and will be replacing them. all i wanted to know is do i need the studs also, for 15 psi, and what kind of BC is good... (no Disrespect, but im not that stupid).
Supra_87_mk3 is offline   Reply With Quote
