Old 10-05-2006, 08:03 PM   #1
ravenmaster
ravenmaster's Avatar
Location: Being not duly informed, I refuse to answer with any degree of accuracy for fear of prevaricating
ravenmaster is on a distinguished road
The intake will take about two seconds to remove. Matter of the screw that holds the hose on the throttle body, and the bolt that holds the afm onto the side wall. As far as the manifold I am too big to even think about reaching all the bolts :-) 200 LBS 6'6", i dunno i could be wrong.
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist View Post
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that.
ravenmaster is offline   Reply With Quote
