Old 09-06-2006, 04:35 AM   #4
newbsupra
newbsupra's Avatar
i have the idle problem.. when i was delivering pizza the last few nights (yea thats right).. my car will start fine, idle fine, run fine.. but then after i make a run or two, my car is warm, i shut it off for 20 minutes, then start it, it idles about 500-600 rpm. going up and down, sputters and die, but if i get on the throttle when i start it, it will sputter, and then finally rev up, then i will rev it up to 3000rpm a couple times, then it will sit at about 900-1000rpm and will run fine.. any idea whats wrong with it? could it be the bolt like yours? could u post a pic of the bolt you tightened? thanks
