Old 03-16-2006, 09:08 PM   #1
Suprapowaz!
Suprapowaz! is on a distinguished road
remove the head. take the valves out of one cylinder. place a good size block of wood in that one cylinder with the missing valves. install the head back on. the block of wood will stop the crank from turning so you can break that bolt free. or maybe the head will crack with all the pressure... i don't know. i haven't tried it.
Just kidding, do not try this.
yeah... have a friend help you keep the flywheel from turning. use at least 1/2" drive ratchet and long breaker bar. eat you wheaties first then have at it.
Suprapowaz! is offline   Reply With Quote
