Thread: Spark advance
Old 11-06-2013, 07:10 PM   #1
btwilson86
Super Moderator
btwilson86's Avatar
Shaving the head does slightly decrease the distance between the cam gears and tge crank gear, which i believe could make it difficult to set your camshafts perfectly with the crankshact (due to the set length and number of teeth on the timing belt). If the underlying cause of your problem is the camshafts (specifically the exhaust cam) not lined up correctly with the crankshaft, a set of adjustable cam gears can fix that problem.
I do not know how much material needs to be removed to cause the gears to not line up.
